Status-only access to Gateway?
The Gateway now breaks the pages up by categories: Home, Status, and Config. Status and Config are only accessible if you login as a user with the Administrator role. Is it possible to give a user a role which allows them to access the Status pages without allowing them to access Config?
Status Page Roles in Gateway Settings should get you there: https://docs.inductiveautomation.com/display/DOC80/Gateway+Settings
Perfect! I had thought the Administrator role I was seeing was predefined. I see now that it was just defined as the role which allows Status and Config.
Thanks!
