Hey guys,
I feel like this should be something pretty easy, but I’m not sure how to start.
In my situation, I’m using system.serial commands through an RS-485 converter to talk to 8 counters.
I’m using a system.serial.write to send a command, and system.serial.readLine to get information back from the device. It works awesome.
But, I’m foreseeing a problem. If someone were to unplug one of the counters, it would send an error message every 4 seconds (the write/reads are a timer script to refresh values). The actual error message I would get is “Underlying input stream returned 0 bytes”. The guys running this system are going to have absolutely no idea what that means.
Is there a way to stop an error message through scripting, and instead just write to a tag. The long and short of it is that I want to light up an “Error” label on the screen, rather than annoying popup error every 4 seconds with a message that makes no sense to the guys running the system
Any idea are appreciated!
Thanks!
Austin
