Stop context menu click from propagating to items behind it
Using perspective 8.3.10.
I have a right-click context menu on a component, and one of the items in it runs a method which calls a popup. All fine, but when the popup opens, so does another one - because when I clicked the item on the context menu, behind it was an item which also has an onClick item to show a popup.
I understand that this is exactly what the "stop propagation" option is for on events, but this script is called by a custom method, and the custom method doesn't have that option.
How can I have the context menu block the click from passing through to whatever is behind it? I'd hate for the context menu just happen to be over a start button or a stop button or something and have an operator inadvertently start or stop something important.
Just giving this one a bump
In case this helps someone in the future, I raised a support ticket for this and it was confirmed that it's a bug which is currently under investigation. Apparently it only shows up if you've got an onClick event configured on the root container in which the right-clicked object is embedded, which in this case, I do.
+1 on this bug. I've also been running into it when I added context menus for adhoc trending on icons and it launches the faceplate each time.
