Stopping/Starting Ignition Gateway Service
So the GCU is gone in version 8.0 and 8.1. How do you start and stop the Ignition Gateway Service? I’m on Windows Server 2019 and based on the v8 manual, I ran a CMD prompt and did net stop Ignition. I check the service and it now says that it is stopped, but the gateway webpage is still up and running. What is going on here?
Use Windows’ service management interface or the command-line replacement gwcmd.bat.
https://docs.inductiveautomation.com/display/DOC81/Gateway+Command-line+Utility+-+gwcmd
