Store and Forward TagHistoryDatasourceSink "there is already a scheduled task"
Hello, I'm having a repeated warning to the gateway logs from Store & Forward Tag History Datasource Sink "There is a problem checking the tag history database tables during initialization of the store and forward engine which could prevent tag history data from being forwarded properly. Trying again in 60 seconds.":
java.lang.IllegalArgumentException: There is already a scheduled task for taghistorydatasourcesink.prune_task[plantdatacollection]
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine.register(BasicExecutionEngine.java:407)
at com.inductiveautomation.gateway.tags.history.storage.TagHistoryDatasourceSink.startMaintenanceTasks(TagHistoryDatasourceSink.java:580)
at com.inductiveautomation.gateway.tags.history.storage.TagHistoryDatasourceSink.initialize(TagHistoryDatasourceSink.java:298)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:544)
This started recently, we just had issues with the database memory/disk cache full and IT helped by rebooting the database and increasing its' memory (plus I found a query that was running against the database 6000 times per minute which I resolved).
Any help to point me in the right direction would be much appreciated.
After calling tech support, we believe the issue was with the database itself. There is a secondary system which is reading OPC tags and writing to the DB which had a wide assortment of configuration issues and bad paths. After disabling broken items, store and forward began working correctly.
