Stored Procedure Error
Hello,
I am getting the following error while executing a stored procedure call.
Can not insert Null into the identity column. The procedure call worked before, but I am not sure how to fix the issue.
  File "<event:actionPerformed>", line 51, in <module>
  File "<module:shared.notification>", line 46, in add
	at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.error(AbstractDBUtilities.java:364)
	at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.execSProcCall(AbstractDBUtilities.java:492)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
java.lang.Exception: java.lang.Exception: Error executing system.db.execSProcCall()
	at org.python.core.Py.JavaError(Py.java:495)
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:186)
	at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:427)
	at org.python.core.PyObject.__call__(PyObject.java:387)
	at org.python.core.PyObject.__call__(PyObject.java:391)
	at org.python.pycode._pyx17.add$1(<module:shared.notification>:49)
	at org.python.pycode._pyx17.call_function(<module:shared.notification>)
	at org.python.core.PyTableCode.call(PyTableCode.java:165)
	at org.python.core.PyBaseCode.call(PyBaseCode.java:301)
	at org.python.core.PyFunction.function___call__(PyFunction.java:376)
	at org.python.core.PyFunction.__call__(PyFunction.java:371)
	at org.python.core.PyFunction.__call__(PyFunction.java:361)
	at org.python.pycode._pyx16.f$0(<event:actionPerformed>:56)
	at org.python.pycode._pyx16.call_function(<event:actionPerformed>)
	at org.python.core.Py.runCode(Py.java:1275)
	at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:623)
	at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:168)
	at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.access$000(ActionAdapter.java:40)
	at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter$ActionRunner.run(ActionAdapter.java:280)
	at java.awt.event.InvocationEvent.dispatch(Unknown Source)
	at java.awt.EventQueue.access$500(Unknown Source)
	at java.awt.EventQueue$3.run(Unknown Source)
	at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
Caused by: java.lang.Exception: Error executing system.db.execSProcCall()
	... 40 more
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: ORA-01400: cannot insert NULL into ("IGNITION"."NOTIFICATIONS"."ID")
ORA-06512: at "IGNITION.ADD_NOTIFICATION", line 41
ORA-06512: at line 1
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:327)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:301)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:258)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:884)
	at com.inductiveautomation.ignition.client.script.ClientDBUtilities._call(ClientDBUtilities.java:203)
	at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.execSProcCall(AbstractDBUtilities.java:490)
	... 38 more
Caused by: java.sql.SQLIntegrityConstraintViolationException: ORA-01400: cannot insert NULL into ("IGNITION"."NOTIFICATIONS"."ID")
	at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:439)
	at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:395)
	at oracle.jdbc.driver.T4C8Oall.processError(T4C8Oall.java:802)
	at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:436)
	at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:186)
	at oracle.jdbc.driver.T4C8Oall.doOALL(T4C8Oall.java:521)
	at oracle.jdbc.driver.T4CCallableStatement.doOall8(T4CCallableStatement.java:202)
	at oracle.jdbc.driver.T4CCallableStatement.executeForRows(T4CCallableStatement.java:1005)
	at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1307)
	at oracle.jdbc.driver.OraclePreparedStatement.executeInternal(OraclePreparedStatement.java:3449)
	at oracle.jdbc.driver.OraclePreparedStatement.execute(OraclePreparedStatement.java:3550)
	at oracle.jdbc.driver.OracleCallableStatement.execute(OracleCallableStatement.java:4710)
	at oracle.jdbc.driver.OraclePreparedStatementWrapper.execute(OraclePreparedStatementWrapper.java:1374)
	at org.apache.commons.dbcp.DelegatingPreparedStatement.execute(DelegatingPreparedStatement.java:169)
	at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper$SRPreparedStatement.execute(SRConnectionWrapper.java:853)
	at com.inductiveautomation.ignition.gateway.script.GatewayDBUtilities._callSProc(GatewayDBUtilities.java:230)
	at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.CallSProc.call(CallSProc.java:42)
	at sun.reflect.GeneratedMethodAccessor95.invoke(null)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.lang.reflect.Method.invoke(Method.java:483)
	at com.inductiveautomation.ignition.gateway.servlets.gateway.AbstractGatewayFunction.invoke(AbstractGatewayFunction.java:209)
	at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:345)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
	at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:85)
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:816)
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:583)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226)
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1156)
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:511)
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1088)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
	at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:52)
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:119)
	at org.eclipse.jetty.server.Server.handle(Server.java:517)
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:306)
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:242)
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:245)
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:95)
	at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:75)
	at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceAndRun(ExecuteProduceConsume.java:213)
	at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:147)
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:654)
	at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:572)
	at java.lang.Thread.run(Thread.java:745)
Ignition v7.8.1 (b2016012216)
Java: Oracle Corporation 1.8.0_131
Seems pretty obvious–a primary key column cannot be null. You aren’t showing your code that calls this stored procedure, but I recommend adding some logging of the values you are sending.
The primary key is the identity column “ID”. For some reason its not auto-incrementing as it did before.
@pturmel
Please see code below.
create or replace PROCEDURE ADD_NOTIFICATION
P_REQUEST_EMP_ID IN NOTIFICATIONS.REQUEST_EMP_ID%TYPE,
P_LINE_ID IN NOTIFICATIONS.LINE_ID%TYPE,
P_CATEGORY_ID IN NOTIFICATIONS.CATEGORY_ID%TYPE,
P_SEVERITY_ID IN NOTIFICATIONS.SEVERITY_ID%TYPE,
P_LINE_COMPONENT_ID IN NOTIFICATIONS.LINE_COMPONENT_ID%TYPE,
P_REQUEST_NOTE IN NOTIFICATIONS.REQUEST_NOTE%TYPE,
P_CALL_SUPERVISOR IN NUMBER,
P_CALL_MECHANICAL IN NUMBER,
P_CALL_ELECTRICAL IN NUMBER,
P_CALL_QUALITY IN NUMBER,
P_ID OUT NOTIFICATIONS.ID%TYPE
IS
SUPERVISOR_TIME TIMESTAMP;
MECHANICAL_TIME TIMESTAMP;
ELECTRICAL_TIME TIMESTAMP;
QUALITY_TIME TIMESTAMP;
BEGIN
IF P_CALL_SUPERVISOR = 1 THEN
SUPERVISOR_TIME := CURRENT_TIMESTAMP;
ELSE
SUPERVISOR_TIME := Null;
END IF;
IF P_CALL_MECHANICAL = 1 THEN
MECHANICAL_TIME := CURRENT_TIMESTAMP;
ELSE
MECHANICAL_TIME := Null;
END IF;
IF P_CALL_ELECTRICAL = 1 THEN
ELECTRICAL_TIME := CURRENT_TIMESTAMP;
ELSE
ELECTRICAL_TIME := Null;
END IF;
IF P_CALL_QUALITY = 1 THEN
QUALITY_TIME := CURRENT_TIMESTAMP;
ELSE
QUALITY_TIME := Null;
END IF;
INSERT INTO NOTIFICATIONS (REQUEST_EMP_ID, LINE_ID, CATEGORY_ID, SEVERITY_ID, LINE_COMPONENT_ID, REQUEST_NOTE, CALL_TIME_SUPERVISOR, CALL_TIME_MECHANICAL, CALL_TIME_ELECTRICAL, CALL_TIME_QUALITY)
VALUES (P_REQUEST_EMP_ID, P_LINE_ID, P_CATEGORY_ID, P_SEVERITY_ID, P_LINE_COMPONENT_ID, P_REQUEST_NOTE, SUPERVISOR_TIME, MECHANICAL_TIME, ELECTRICAL_TIME, QUALITY_TIME)
RETURNING ID
INTO P_ID;
COMMIT;
END ADD_NOTIFICATION;
You're going to have to fix this in the DB. It isn't an Ignition problem. Your SP code doesn't accept or attempt to insert that ID column, so there's nothing Ignition can do to address this problem.
Thanks for your help @pturmel
