I have a set of tags that perform a calculation that return a datetime. I would like to use a transaction group to store these datetimes to a table, then use the data from the table as a binding property to display the events on a calendar.
When I try to set up the transaction group to save the datetimes to a table in my MSSQL database, I keep getting error saying:
Error forwarding data: implicit conversion from data type datetime is not allowed. Use the CONVERT function to run this query.
I have also tried formatting the tags as strings, and in that case I get the error:
Error forwarding data: conversion failed when converting nvarchar value “2012-04-23 10:48:21” to data type int.
So my question is, what would be the best way to set up the group of tags as events on a calendar? Should I use the transaction group? If so, how do I get the datetimes to save to the database??
Dan
