Strange error when trying to click on panes in Designer
Currently on Ignition 8.0.2. I encounter this error in the console whenever I attempt to click within the main designer pane or the component palate in the Ignition Designer. Any thoughts on why this may be happening?
Exception in thread "AWT-EventQueue-0" java.lang.ClassCastException: class javax.swing.plaf.synth.SynthRootPaneUI cannot be cast to class de.javasoft.plaf.synthetica.SyntheticaRootPaneUI (javax.swing.plaf.synth.SynthRootPaneUI is in module java.desktop of loader 'bootstrap'; de.javasoft.plaf.synthetica.SyntheticaRootPaneUI is in unnamed module of loader java.net.URLClassLoader @19cd9d83)
at de.javasoft.plaf.synthetica.painter.RootPanePainter.paintRootPaneBorder(RootPanePainter.java:160)
at com.jidesoft.plaf.synthetica.SyntheticaFrameBorder.paintBorder(SyntheticaFrameBorder.java:36)
at java.desktop/javax.swing.JComponent.paintBorder(Unknown Source)
at java.desktop/javax.swing.JMenuBar.paintBorder(Unknown Source)
at com.jidesoft.action.CommandBar.paintBorder(Unknown Source)
at java.desktop/javax.swing.JComponent.paint(Unknown Source)
at java.desktop/javax.swing.JComponent.paintChildren(Unknown Source)
at java.desktop/javax.swing.JComponent.paintToOffscreen(Unknown Source)
at java.desktop/javax.swing.RepaintManager$PaintManager.paintDoubleBufferedFPScales(Unknown Source)
at java.desktop/javax.swing.RepaintManager$PaintManager.paintDoubleBuffered(Unknown Source)
at java.desktop/javax.swing.RepaintManager$PaintManager.paint(Unknown Source)
at java.desktop/javax.swing.RepaintManager.paint(Unknown Source)
at java.desktop/javax.swing.JComponent._paintImmediately(Unknown Source)
at java.desktop/javax.swing.JComponent.paintImmediately(Unknown Source)
at java.desktop/javax.swing.RepaintManager$4.run(Unknown Source)
at java.desktop/javax.swing.RepaintManager.paintDirtyRegions(Unknown Source)
at java.desktop/javax.swing.RepaintManager.prePaintDirtyRegions(Unknown Source)
at java.desktop/javax.swing.RepaintManager$ProcessingRunnable.run(Unknown Source)
I'm having same error in designer. could you solve it?
What version of Ignition are you using? There's a bug with the same Exception noted that was fixed in version 8.1.8.
I'm using 8.1.7. should I upgrade?
Yes, try upgrading to whatever the most current release is.
