I am using a Row selector output as the data input to a table. I am then using a property with the expression:
{Root Container.Table.data}[0, “batch_num”]
The purpose of this is to retrieve a single relevant cell from the database for use as an input in another row selector. While the property reads the correct value I am continually receiving an error:
Exception: Error executing expression binding on
Main Window.Root Container.Numeric Label.value
caused by IndexOutOfBoundsException: Index: 0, Size: 0
Ignition v7.1.7 (b6048)
Java: Sun Microsystems Inc. 1.6.0_22
Is there a method of catching an error? How would I go about fixing this problem?
