Strange HMI refreshing behaviors (7.6.2)
Ignition Version : 7.6.2 (b2368)
Java Version : Oracle Corporation 1.7.0_25
win 7 32 bits
I have some strange HMI refreshing behaviors
  1. When I change user, Permissions on components are not refreshed.
    When I change the current windows and reload the previous one, Permissions on components are not refreshed.
    I need to close the vision client and to relaunch it to have the permissions on components refreshed.
  2. When I modify a windows in the designer, close the windows and save and publish, click to update in the vision client, the windows is not refreshed.
My Navigation is based on a tabstript component in the left bar for the first menu level,
and a tab strip component in the north bar.
All the windows are opened with “Swap to windows” tabstrip or with system.nav.swapTo
Mains Windows are configured with :
closable=true
maximizable=false
resizable=true
Start Maximized= trie
Cache policy=Auto
Dock position=Floating
Do have 7.6.2 release some known HMI refreshing issues ?
To clarify:
  1. So when you logout of the client, and log back in with the appropriate user, the security settings on components are not updated? I can’t reproduce this.
  2. Are you sure you’re clicking “Yes” on the “Commit Changes” window when closing it?
I tested a basic scenario, there may be some settings your users/projects/components are using that I don’t have in my test project. I will PM you a ticket number to upload a gateway backup to.
sorry for the item 1) the problem is with system.security.switchUser
Logout (with system.security.logout()) is generally OK, but sometime, I've the following error :
Both switchUser() and logout() are working fine for me, I’ll have to see your project. I now edited the ticket so it can accept your gwbk upload, sorry about that.
Hi James,
Did you reproduce hmi issues with my backup ?
Regards.
lionel
:thumb_left: :thumb_left: :thumb_left:
Thanks James for the fix in my script, I missed to filter event :
event.propertyName==‘selectedTab’:
this solved all my navigation problem, and fuzzy operating !
