I have strange shift on my vision clients. They have +1 hour to the time displayed on the screen. Also the trends are shifted with 1 hour. I also have time dependant reports, which also not working as expected. Here are the system tags for the times for the client and gateway:
As you can see the time is about +1 hour shifted on the client from the gatewaw. The gateway has no internet connection and cannot use time auto update.
The progect confituration for the timezone behavior:
Here is the system information for the gateway:
Environment
Process Id 3924
Operating System Windows 10 | amd64
Java Version 11.0.7+10-LTS
Local Time 7:10:32 a.m.
Available Disk Space 363gb / 465gb
Detected NICs 192.168.10.5
Systems
Alarm Pipelines 0 / 10 active
Modules 10 installed
Performance 3% CPU | 817mb
Redundancy Not configured
Reports 7 scheduled
Tags 11,844 tags
The clients are on different timezones and the problem is the same on every client.
The gateway timezone is reported by powershell as:
PS> Get-Timezone
Id : Mountain Standard Time
DisplayName : (UTC-07:00) Mountain Time (US & Canada)
StandardName : Mountain Standard Time
DaylightName : Mountain Standard Time
BaseUtcOffset : -07:00:00
SupportsDaylightSavingTime : False
The timezone on the gateway was misconfigured with SupportsDaylightSavingTime to True at the beginning, but was changed to the correct daylight saving setting. The local clients are correctly configured from the beginning.
Is there a way to fix this problem?
Thank you.
