Hi there. I’m curious if there is a way to do a string contains type function in the expression binding on a custom property. For example, something like string.contains(‘search_data’) - something similar to that. Is there anything like that in Ignition?
You might be able to use indexOf
Yes this is perfect, thank you!
Does this require a function? Can you provide an example?
Sorry to bump ancient thread... but for anyone passing by:
Example to see if string contains another string (note it is case sensitive):
if( indexOf("ignition", "itio") != -1, doSomethingIfTrue(), fallback() )
