I’m trying to populate the Text Field of a label with the Address of a PLC Item from the OPCItemPath. The problem I’m having is you cannot directly access the Meta Data of a UDT in a Template. I’ve added my UDT to the Template as a parameter and I can indirectly access the Meta Data using the indirect tag feature and then pointing to the Tag.OPCItemPath. However, I wanted to use the expression binding and use the Right Fucntion to strip off the Address in the PLC for populating the Label. I can’t seem to find a work around?
Any ideas?? ![]()
