Stuck at "Connecting" in multiple spots
When trying to access the project through the web browser, it allows me to login but gets stuck at “connecting” with the ignition splash screen. I tried opening a view to make edits, and it also got stuck at “connecting”. What’s going on here? Any ideas?
I don’t know if it applies to your configuration but this can happen when you have a redundancy server that’s not configured correctly.
Break the connection or stop the service on the redundancy server and see if your projects load.
Not sure, but could you have port 8088 open to get to the web browser but have port 8060 blocked?
Gateway Port Reference | Ignition User Manual
That’s most likely it. Awesome suggestion. I’m trying to get things set up with a customer and their IT most likely whitelisted 8088, but not 8060. Thanks and I’ll keep you posted if that works.
We got it working. The IT person I was working with said this “TCP connections was failed , firewall understand its a bad connection. so i have defined the proper application name. so firewall accepted the connection”.
I’m not entirely sure what it means from an IT standpoint. He said there was only traffic on 8088. We left 8060 and 8043 open even though we weren’t using them.
