Studio5000 tag description
Is there a way to get the plc tag description to ignition designer tags ?
thank you
No, sorry, Rockwell does not expose this information. Or they don't document it, at least.
Not conveniently, no. The best bet would be an XML parse of the *.L5X format and turn that into a format you could use with a tag configuration jython script. Non-trivial, unfortunately.
