Im trying to fill the warning icon red by calling the Warning class I created
I added color to the right property but the color is not changing
If you are calling it through classes are you suppose to add color to a different property?
Hi @retinder.labana, you will need to use the text color property instead.
I take no credit, I just remembered this post which @swolnisty found the solution to a little while ago.
Thank you Mathew
Maybe they fixed ithis, but you used to also have to set the props colour to ‘unset’ as well so that it wouldn’t override the style.
