Stylesheet Scripting
I'm going to go ahead and guess that there's no way to programmatically update the CSS stylesheet through scripting to alter themes "on-the-fly"? Might there be another way to do that? Maybe editing the actual stylesheet file on the gateway? I'm not sure where it's located.
What is the use case/reason behind wanting to?
It looks like the file is located at:
C:\Program Files\Inductive Automation\Ignition\data\projects\PROJECT_NAME\com.inductiveautomation.perspective\stylesheet\stylesheet.css
You should be able to edit it externally (or via scripting), and the changes will be picked up every 5 minutes via the gateway.
I want to alter styles on the fly to see changes to variable (color) definitions in real-time and using a color picker, so I don't have to mess with hex codes so much. I could then use this to quickly make new styles using a script to save the current stylesheet as a style in the install directory.
Not sure about amarks, but I have ours setup to edit a different css file to add css definitions on a per-user basis
And I'm guessing that 5 minutes is constant? I can't force an update?
Supposedly, the ability to force an update is a planned feature:
That's a slightly different ask; the asset managers that watch for themes, icon sheets, and fonts for Perspective are supposed to be automatic and pick up changes immediately.
I know some of the changes I make require me to log out and back in before they take affect, at least in the client.
you can use the inspector in the browser to add and modify styles on the fly to have instant feedback, and copy the styles to your stylesheet
That's what I was about to say. Seems to be the simplest and most effective solution to that use case.
