yehuda 29MAR06 - Is it be passable to create many sub folder in the main folder on factory SQL?
Nathan 29MAR06 - Yes, check out “Group Folders” versus “Groups” in the FactorySQL manual.
yehuda 29MAR06 - Yes but I meant, if I Can create sub folder inside the group for example:
plant3\Hvac\plc2\tt_02
Because we use RSLOGIX 5000 it make more sense we make the TAGS is the FactorySQL
The same way that we built in RSLOGIX 5000 .
Is it be Passable to do that?
Colby.Clegg 30MAR06 - Hello,
Unfortunately, at this time that is not possible. This functionality is tentatively scheduled for version 2.3, which should arrive in a few months. It’s possible that it could make it into 2.2, due out in about 2-3 weeks, but it’s doubtful.
Thank you for your inquiry,
Colby Clegg
Software Engineer
Inductive Automation
clegg@inductiveautomation.com
