I sent my module to support@inductiveautomation.com to be signed. Is this the process for getting a module signed or is there an automated system?
There is an automatic way to sign modules in a special developer portal. To gain access you have to added by us manually. I have added you so login here:
Could I be granted access as well, please?
Ok, you have been added.
I need to sign 2 modules.
Ok you have been added as well.
Ok, you have been added as well.
May I be added as well? I have a little tag provider module that I need signed, and I may need to write a few more, similar modules.
Added
Added
And me! And me!
Thank you.
demyansda, you are added!
Good day. I am a registered developer user, I have a CD-Key. But when I access to the “Developer Portal Login” I have the answer “You do not have Sufficient Privileges to login”.
I need to sign a module, why I can’t login as “Developer” to sign a module?
Greetings, thank you very much.
We have to add you to that group in order to sign modules. I have added you. Try it again.
I also need to be added to the developer group.
Also, I’m not sure why, but my developer CD Key that I was sent in 2010 is giving me the “no activations left” message, although I don’t remember ever using it. If you can reset the counter or send a new key, that would be great.
[quote=“Step7”]I also need to be added to the developer group.
Also, I’m not sure why, but my developer CD Key that I was sent in 2010 is giving me the “no activations left” message, although I don’t remember ever using it. If you can reset the counter or send a new key, that would be great.[/quote]I have added you as well. I have also emailed you another developer key.
Can I please be added as well?
I could still use a new cd-key and access to the Dev Portal as of 8/21/13.
