I am looking to split the legend when I have subplots. Right now it just puts all the tags into the same box and it’s hard to tell which tags are on which plot.
Assuming Vision
To do this, you have to create a template with a easy chart.
Then use a template repeater that uses that template
It is a hard work because you should create parameters in the template to decode datasets for tag or db pens and strings and bunch more properties to achieve full functionality.
