Subscribe to UDT Parameters property for value changed?
@mgross, @paul-griffith
I try to subscribe to UDT Parameters property value changed with:
public abstract java.util.concurrent.CompletableFuture<Void> subscribeAsync(java.util.List<com.inductiveautomation.ignition.common.tags.model.TagPath> list,
        java.util.List<com.inductiveautomation.ignition.common.tags.model.event.TagChangeListener> list1)
It seem I receive the initial notification, but when the value change and dont’ receive any change notification.
is subscribeAsync the right function to use for UDT Parameters property ???
I was able to get my subscription listener to fire multiple times, but I was using nightly code as of 9/25. Here is what I did:
TagPath paramPath = TagPathParser.parse("[default]Basic UDT instances/BasicUDT_Instance0/Parameters.MyParam");
SubscriptionListener listener = new SubscriptionListener(paramPath);
tagManager.subscribeAsync(paramPath, listener).get(TIMEOUT, TimeUnit.SECONDS);
QualifiedValue qv = new BasicQualifiedValue("new value");
List<QualityCode> qc = defaultProvider.writeAsync(
            Arrays.asList(paramPath), Arrays.asList(qv), SecurityContext.emptyContext())
Thanks, I use a TagChangeListener instead of SubscriptionListener with a build before 9/25.
I'll try to test again with the last nightly.
Oh sorry, I was using my own implementation of TagChangeListener that I called SubscriptionListener.
I have not implemented getTagProperty in the TagChangeListener.
By default, Value is used for the subscribed tags or subscribed udt instance parameters ?
or I need to add something like:
    public TagProp getTagProperty(){
        return TagProp.Value;
I think you are using the wrong TagChangeListener class. You want to be using this one:
The tagChanged() method passes a TagChangeEvent, where you can get the changed value using getValue().
@mgross, I have to do more test, but I subscribe with:
[default]Basic UDT instances/BasicUDT_Instance0/Parameters/MyParam
instead of:
read operation is possible with Parameters/MyParam but perhaps subscribe is not possible ?
@mgross,
It’s OK for subscription with:
instead of:
