I just did a fresh install of Ignition 8.0.15 on CentOS 7.8.2003. It installed and I can access the Gatweay Web page. However the usual LInux service commands do not work. For example:
sudo service ignition status or sudo service ignition restart
The result is:
ignition]$ sudo service ignition status
Redirecting to /bin/systemctl status ignition.service
Unit ignition.service could not be found.
The last fresh install I did was 8.0.12…worked fine
Similarly, I use the following command to automatically restart Ignition upon reboot. It also fails.
sudo systemctl enable ignition
Failed to execute operation: No such file or directory
