how to bind all the values M1 to M8 in the series property binding.
"example": {
"ds",
192,
1695960797878
"$columns": [
"name": "time",
"type": "Date",
"data": [
1695925800000,
1695925800000,
1695925800000,
1695925800000,
1695925800000,
1695925800000,
1695925800000,
1695925800000
"name": "M1",
"type": "Double",
"data": [
null,
null,
null,
null,
null,
null,
380.0,
null
"name": "M2",
"type": "Double",
"data": [
null,
null,
null,
null,
null,
null,
null,
600.0
"name": "M3",
"type": "Double",
"data": [
null,
null,
null,
100.0,
null,
null,
null,
null
"name": "M4",
"type": "Double",
"data": [
null,
null,
null,
null,
0.0,
null,
null,
null
"name": "M5",
"type": "Double",
"data": [
null,
6.0,
null,
null,
null,
null,
null,
null
"name": "M6",
"type": "Double",
"data": [
null,
null,
76.0,
null,
null,
null,
null,
null
"name": "M7",
"type": "Double",
"data": [
null,
null,
null,
null,
null,
17.0,
null,
null
"name": "M8",
"type": "Double",
"data": [
38.0,
null,
null,
null,
null,
null,
null,
null
Named Query :
SELECT cast(Mod_Date as date) as time
,CASE WHEN (Machine = 1) THEN
(max(convert(float,KWH))-min(convert(float,KWH)))
END AS M1
,CASE WHEN (Machine = 2) THEN
END AS M2
,CASE WHEN (Machine = 3) THEN
END AS M3
,CASE WHEN (Machine = 4) THEN
END AS M4
,CASE WHEN (Machine = 5) THEN
END AS M5
,CASE WHEN (Machine = 6) THEN
END AS M6
,CASE WHEN (Machine = 7) THEN
END AS M7
,CASE WHEN (Machine = 8) THEN
END AS M8
from Main where Mod_Date between :st and :sp and BG=:bg and Plant=:pl and Line =:ll and KWH !='0'
GROUP BY cast(Mod_Date as date),Machine
order by time asc;
x axis Binding:
"name": "time",
"label": {
"enabled": false,
"text": "Day",
"color": "#000000"
"inversed": false,
"visible": false,
"tooltip": {
"enabled": true,
"text": "",
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"render": "date",
"category": {
"break": {
"enabled": false,
"startCategory": "",
"endCategory": "",
"size": 0.05
"date": {
"baseInterval": {
"enabled": true,
"timeUnit": "day",
"count": 1,
"skipEmptyPeriods": false
"range": {
"max": "",
"min": "",
"useStrict": false
"break": {
"enabled": false,
"startDate": "",
"endDate": "",
"size": 0.05
"inputFormat": "yyyy-MM-dd hh:mm:ss",
"format": "M/d/yyyy HH:mm:ss"
"value": {
"range": {
"max": "",
"min": "",
"useStrict": false
"logarithmic": false,
"break": {
"enabled": false,
"startValue": 0,
"endValue": 100,
"size": 0.05
"format": "#,###"
"appearance": {
"opposite": false,
"inside": false,
"labels": {
"color": "#000000",
"opacity": 1,
"rotation": 0
"grid": {
"color": "",
"opacity": 0,
"dashArray": "",
"minDistance": 60,
"position": 0.5
"font": {
"size": ".1",
"weight": 10
"name": "t2",
"label": {
"enabled": true,
"text": "",
"color": ""
"inversed": false,
"visible": true,
"tooltip": {
"enabled": true,
"text": "",
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"render": "date",
"category": {
"break": {
"enabled": false,
"endCategory": "",
"size": 0.05
"date": {
"baseInterval": {
"enabled": true,
"timeUnit": "day",
"count": 1,
"range": {
"max": "",
"min": "",
"useStrict": false
"break": {
"enabled": false,
"startDate": "",
"endDate": "",
"size": 0.05
"inputFormat": "yyyy-MM-dd kk:mm:ss",
"format": "M/d/yy"
"value": {
"range": {
"max": "",
"min": "",
"useStrict": false
"break": {
"enabled": false,
"startValue": 0,
"endValue": 100,
"size": 0.05
"format": "#,###.##"
"appearance": {
"opposite": false,
"inside": false,
"labels": {
"color": "#000000",
"opacity": 1,
"rotation": 55
"grid": {
"color": "",
"opacity": 1,
"dashArray": "",
"minDistance": null,
"position": 0.5
"font": {
"size": 15,
"weight": 1000
Series Binding:
"name": "M1",
"label": {
"text": "EnergyMeter1"
"visible": true,
"hiddenInLegend": false,
"defaultState": {
"visible": true
"data": {
"source": "example",
"x": "time",
"y": "M1"
"xAxis": "t2",
"yAxis": "D",
"zIndex": 1,
"tooltip": {
"enabled": true,
"text": "{name}: [bold]{valueY}[/]",
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"render": "line",
"candlestick": {
"open": {
"x": "",
"y": ""
"high": {
"x": "",
"y": ""
"low": {
"x": "",
"y": ""
"appearance": {
"fill": {
"color": "",
"opacity": 1
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"stacked": false,
"deriveFieldsFromData": {
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"heatRules": {
"enabled": false,
"max": "",
"min": "",
"dataField": ""
"column": {
"open": {
"x": "",
"y": ""
"appearance": {
"fill": {
"color": "",
"opacity": 1
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"width": null,
"height": null,
"stacked": false,
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"heatRules": {
"enabled": false,
"max": "",
"min": "",
"dataField": ""
"line": {
"open": {
"x": "",
"y": ""
"appearance": {
"connect": true,
"tensionX": 1,
"tensionY": 1,
"minDistance": 0.5,
"stroke": {
"width": 3,
"opacity": 1,
"color": "#000080",
"dashArray": ""
"fill": {
"color": "#D9D900",
"opacity": 0
"bullets": [
"enabled": true,
"render": "circle",
"width": 10,
"height": 10,
"label": {
"text": "{value}",
"position": {
"dx": 0,
"dy": 0
"tooltip": {
"enabled": true,
"text": "Energy Meter 1\nkWh: [bold]{valueY}[/]\nDate: [bold]{dateX}[/]",
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"fill": {
"color": "#000080",
"opacity": 1
"stroke": {
"color": "#FFFFFF",
"width": 1,
"opacity": 1
"rotation": 0,
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"rotation": ""
"heatRules": {
"enabled": false,
"max": 100,
"min": 2,
"dataField": ""
"stepLine": {
"open": {
"x": "",
"y": ""
"appearance": {
"connect": true,
"tensionX": 1,
"tensionY": 1,
"minDistance": 0.5,
"stroke": {
"width": 3,
"opacity": 1,
"color": "",
"dashArray": ""
"fill": {
"color": "",
"opacity": 0
"bullets": [
"enabled": true,
"render": "circle",
"width": 10,
"height": 10,
"label": {
"text": "{value}",
"position": {
"dx": 0,
"dy": 0
"tooltip": {
"enabled": true,
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"fill": {
"color": "",
"opacity": 1
"stroke": {
"color": "",
"width": 1,
"opacity": 1
"rotation": 0,
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"rotation": ""
"heatRules": {
"enabled": false,
"max": 100,
"min": 2,
"dataField": ""
"name": "M2",
"label": {
"text": "EnergyMeter2"
"visible": true,
"defaultState": {
"visible": true
"data": {
"x": "time",
"y": "M2"
"xAxis": "t2",
"yAxis": "D",
"zIndex": 0,
"tooltip": {
"enabled": true,
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"render": "line",
"candlestick": {
"open": {
"x": "",
"y": ""
"high": {
"x": "",
"y": ""
"low": {
"x": "",
"y": ""
"appearance": {
"fill": {
"color": "",
"opacity": 1
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"stacked": false,
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"heatRules": {
"enabled": false,
"max": "",
"min": "",
"dataField": ""
"column": {
"open": {
"x": "",
"y": ""
"appearance": {
"fill": {
"color": "",
"opacity": 1
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"width": null,
"height": null,
"stacked": false,
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"heatRules": {
"enabled": false,
"max": "",
"min": "",
"dataField": ""
"line": {
"open": {
"x": "",
"y": ""
"appearance": {
"connect": true,
"tensionX": 1,
"tensionY": 1,
"minDistance": 0.5,
"stroke": {
"width": 3,
"opacity": 1,
"color": "#800000",
"dashArray": ""
"fill": {
"color": "",
"opacity": 0
"bullets": [
"enabled": true,
"render": "circle",
"width": 10,
"height": 10,
"label": {
"text": "{value}",
"position": {
"dx": 0,
"dy": 0
"tooltip": {
"enabled": true,
"text": "Energy Meter 2\nkWh: [bold]{valueY}[/]\nDate: [bold]{dateX}[/]",
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"fill": {
"color": "#800000",
"opacity": 1
"stroke": {
"color": "#FFFFFF",
"width": 1,
"opacity": 1
"rotation": 0,
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"rotation": ""
"heatRules": {
"enabled": false,
"max": 100,
"min": 2,
"dataField": ""
"stepLine": {
"open": {
"x": "",
"y": ""
"appearance": {
"connect": true,
"tensionX": 1,
"tensionY": 1,
"minDistance": 0.5,
"stroke": {
"width": 3,
"opacity": 1,
"color": "",
"dashArray": ""
"fill": {
"color": "",
"opacity": 0
"bullets": [
"enabled": true,
"render": "circle",
"width": 10,
"height": 10,
"label": {
"text": "{value}",
"position": {
"dx": 0,
"dy": 0
"tooltip": {
"enabled": true,
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"fill": {
"color": "",
"opacity": 1
"stroke": {
"color": "",
"width": 1,
"opacity": 1
"rotation": 0,
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"rotation": ""
"heatRules": {
"enabled": false,
"max": 100,
"min": 2,
"dataField": ""
