Hello!
In the menu-bar Perspective has as default Theme selector there is no a built-in color so dark themes have dark letter.
I added the --neutral-90 color and works fine.
Cheers.
Hello!
Cheers.
What is theme dropdown? is that a new component? cus the normal dropdown definitly has a color.
Maybe you are overriding it somewhere
HI!
I mean the default menu in an Ignition Perspective starting project, has a dropdow which allows you to choose themes and this dropdown does not include theme colors itself
every dropdown should have, but maybe that Header/dropdown class overwrites it by accident
Where is this?
well, I didn´t touch those styles, maybe an older versión...
there is no color defined in the style?
That style was also provided by the template, but maybe you editted it, or maybe an different version has that as default no idea
