I am using a Perspective Table and I would like to sum up the values in one of the column and show them in a LED display. Is it possible if I can do that in Ignition?
The only golfing I’d do with Cody’s suggestion is add that the square brackets for the list comprehension aren’t required; since sum is already a terminal operation and only requires visiting each element once, you don’t need to collect the results into a list at all (and thus you can save some memory):
sum(row.population for row in value)
I couldnt see the screenshot , could you please reattach the screenshot again please!
Because your props.data is a dataset, instead of a list of values. You’ll need to iterate through the rows of your Dataset, or get just the column you’re trying to sum.
sum(value.getColumnAsList(x)) # where x is the index of the column you're trying to sum
sum(value.getColumnAsList(value.getColumnIndex("columnName")))
As long as the column is in fact numeric, that should work.
EDIT: Good catch Cody
Thanks Cody, that worked
