Superscript in label component in Perspective
I have a label component in Perspective showing an analogue value of cubic meters. I want to show the unit as m^3 (where the number 3 is in superscript). Is this possible in Perspective at the moment?
In Vision I would do it as <html>m<sup>3</sup>, however that doesn’t work in Perspective.
Have I missed the obvious solution here?
Thanks!
Probably the easiest solution: Use the unicode superscript character; eg: m³
Thanks!
Can’t believe I didn’t think of that…:sweat_smile:
You could also use a Markdown component instead of the Label. The Markdown component allows for HTML, so you could use the same method as you did in Vision.
Perfect thank you. I will check that out. :+1:
