Hello
We are doing a conversion of custom software to ignition edge and need to support decimals in our tag names for the legacy system. Since ignition edge doesn't allow decimals in tag names, we need to convert the 34_5 to 34.5 in the sparkplug ddata message. Are pipeline is ignition edge -> hivemq -> ignition engine.
Example
Before: MTR_34ddd5kV_ALT_A_Phase_Current (I put ddd because it's easier to find than _)
After: MTR_34_5kV_ALT_A_Phase_Current
I've tried 2 methods described below and thought of implementing other options. One would be to just go json instead of sparkplug, but that really isn't something anyone wants to do. Also there was another idea floated of modifying the Tahu code base to decode Sparkplug. I don't really like any of these options, so if anyone has a suggestion for another method, I'm all ears
Method: Namespace string conversion
Concern:
That is on engine side and the 34.5 wouldn't actually be shown in the ddata when subscribing to spBv1.0/edge/DDATA/WAD1/WAD1.
It was always giving errors (likely a config issue)
More Information
- I'm probably not going to continue down this path unless I was thinking about it incorrectly or if there is a namespace string conversion that can be used at edge instead of engine.
Method: Manually pushing ddata to hive from edge using on tag change and system.cirruslink.transmission.publish
Concern:
Had to turn off RPC. Not sure if it'll cause problems
It sends as json and not sparkplug_b format
I can't find the sparkplug_b
More Information:
- The code below gives no module available on both edge and engine even though I see other people online find the modules.
try:
import sparkplug_b as sparkplug
from sparkplug_b import addMetric, MetricDataType
from com.cirruslink.sparkplug.message.model import MetricDataType
from com.cirruslink.sparkplug.message.model.SparkplugBPayload import SparkplugBPayload, Metric
except ImportError as e:
print(e)
- What I'm currently doing, but I don't really like the technique. I have a tag change event script on the tags. Also it doesn't quite work for us because it shows up as json and not sparkplug
import system
from java.lang import String
# Define MQTT properties
topic = "spBv1.0/edge/DDATA/WAD1/WAD1"
qos = 0 # Quality of Service level
retain = False # Retain flag for the message
clientId = "debugClient" # Provide a client ID for the connection
# Define the original tag name and value (hardcoded for testing purposes)
original_tag = "AAD1_xxxxxxx_SUB0001_MTR_34ddd5kV_ALT_A_Phase_Current"
value = currentValue.value # Example value, replace with dynamic value if needed
data_type = "Float" # Example data type
# Function to process tag name
def process_tag_name(tag):
return tag.replace("ddd", ".")
# Convert the tag name
converted_tag = process_tag_name(original_tag)
# Create the Sparkplug-like payload
payload = {
"timestamp": system.date.now().getTime(), # Include timestamp
"metrics": [
"name": converted_tag,
"timestamp": system.date.now().getTime(), # Each metric can have a timestamp
"dataType": data_type,
"value": value
# Serialize the payload to JSON bytes
payload_json = system.util.jsonEncode(payload)
payload_bytes = String(payload_json).getBytes("UTF-8")
# Publish the message to the broker
system.cirruslink.transmission.publish("HSD", topic, payload_bytes, qos, retain)
- What I think we need to do on the tag change event, but can't get the modules to import
import system
print("Loaded Sparkplug classes successfully.")
# Additional checks can be added after this line to verify each import.
# Proceed with the rest of your code...
qos = 0
retain = False
original_tag = "AD1_xxxxxxx_SUB0001_MTR_34ddd5kV_ALT_Phase_A_KVA"
value = 12345
payload_builder = SparkplugBPayload.newBuilder()
timestamp = system.date.now().getTime()
metric_builder = Metric.newBuilder()
metric_builder.setName(converted_tag)
metric_builder.setDatatype(MetricDataType.Int32)
metric_builder.setIntValue(value)
metric_builder.setTimestamp(timestamp)
payload_builder.addMetrics(metric_builder.build())
payload = payload_builder.build()
payload_bytes = payload.toByteArray()
system.cirruslink.engine.publish("HSD", topic, payload_bytes, qos, retain)
Thank you!!!
