Support for COMTRADE files
Does Ignition support display of CONTRADE files from disturbance recorders in electrical relays?
Ignition has the graphing components you would need, from what I can tell, but it doesn't have any support for COMTRADE built in.
Ok fine. We can convert the COMTRADE files into SQL format required by ignition for the trends display. Of course there are off line tools available for display of these graphs, but having them built in ignition will be an advantage especially for substation automation.
You might be able to do something with this:
That’s a great information. We can use scripts in ignition to import these in sql and use the trend feature of ignition. Its MIT licensed as well so quite flexible to use.
Thanks for sharing.
Best Regards
