A clipping mask effect is applied to the svg vector file, but if you move it to Ignition, the effect is removed.
It will be a while but if you can provide the SVG file, I can work one up that will work in Ignition. Clipping masks can be used, but when dropping in files from outside of ignition they don’t always get interpreted correctly.
I asked this question because a similar situation occurred when a designer was testing an image while creating it.
What are some things to consider when working with images?
Tanks for your answer.
