SVG Gradient issue
i created simple rectangle to explain the issue which i faced .
  • need to control stop offset for Gradient
    in SVG .
    the view will be as Embeded view and will used different time with Parm to control the Gradiant value .
    what i faces offset only change for both views with the first view dropped in the designer.
    attached the SVG source, and views which used for test .
    Issue.zip (5.1 KB)
ShareX_UiGXH88wGP
This is a known issue. Please see this post: [BUG-6988]Embedded View "Template" Instance Behavior
This was fixed as part of the 8.1.26 release.
