Hi anytime I import an svg from google drawing i get this error.
ignition 8 is getting better svg support in a later update.
For the moment, it’s not a big problem.
The issue is because the SVG you’re importing defines measurements as a string (f.e. “12px” instead of “12”).
If you want to avoid these errors, you can open the SVG with a text editor (notepad++ f.e.), and remove all the “px” references (or whatever unit is used) by yourself.
