I can successfully drag & drop an SVG into an Ignition designer version 7.9.6, but I get a NullPointerException with an Ignition designer version 8.0.12 using the Vision module.
I’m using Windows 10 and the same SVG for both designers.
Here is the error:
[AWT-EventQueue-0] ERROR com.inductiveautomation.ignition.client.util.gui.ErrorUtil - Error creating shapes.
java.lang.NullPointerException: null
at com.inductiveautomation.factorypmi.designer.workspace.DropHandler$SvgImporter.run(DropHandler.java:366)
Is the 8 server missing an SVG handler? None of the SVGs that work on the 7.9 server will show on the 8 server.
