SVG text and styles
I have embedded a simple SVG into a view. Later proceeded to add a couple of text objects within Ignition. I then added the style object within the text element and chose the style I have already created. It has taken all the configuration of the style except the colour. I then tried to add the colour by trying to use "color" and "paint" but both did fail. (I have tried inside style and outside) If I inspect the element the "color" is not crossed out. So why isn't the text not taking the colour?
Found a solution as I was looking through options in the style editor. Apparently, I need to use "fill" in the style definition and not the text colour.
