Swap to Popup with Different Dimensions
Many of my popups include navigation to other popups. For example, if a given pressure sensor is used to determine the position of a valve, I can get to the valve popup from the sensor popup and vice versa. Most of my popups have the same dimensions, so the function system.nav.swapWindow works well. However, a few of my popups are bigger. The system.nav.swapWindow function forces the opened popup into the same dimensions as the closed popup.
Is there a way to swap to a new popup, such that the new popup is at the same coordinates as the old popup, but with its default dimensions?
.swapWindow is really designed for maximized main windows. I don't recall anyone using it with popups. You should just make a shared script that opens the new popup, moves it to the position of the old popup, and closes the old popup.
Okay. That sounds like a good plan.
Just checking... As far as you know, there is no function that to reset the dimensions of a popup? Then I could do a swap followed by dimension reset.
Perhaps one of these posts will be helpful?
https://forum.inductiveautomation.com/search?q=perspective%20popup%20resize
This post is Vision.
Not that I'm aware of. Just don't use swap for popups.
Oops :slight_smile:
Got it. Thank you!
