Hello,
I recently switched from WinCC to Ignition Perspective for big projects and am looking to build our company library. Are there any obvious tips & tricks and notes to keep in mind when making template views & popups for pumps, valves etc? What is the best performance wise when using dropconfig udt? Path or Bind?
Can i remove parts of the Bind that i'm not using in the template?
I assume I will use alot of template views & piping for my projects. Calling for a popup to be openend to control/monitor the views.
Also I can't really find an easy way to filter the operations log. If I enter parts of a tag, it won't find it unless I filter by using the starting text (eg DB_Sensor.SensorA wont filter by typing SensorA)
Any tips for transitioning from WinCC to Ignition and keeping smooth performance?
