I having a box and whisker chart and a parameter power table. In the power table can I select a parameter. I want to switch between the dataset depending on the selected parameter in the power table. The datasets and the selected parameters are custom properties.
I used this script what i run in the property change of the box and whisker chart:
if event.source.parent.Selectedparameter == ‘Perstijd’:
event.source.data = event.source.parent.Perstijd
if event.source.parent.Selectedparameter == ‘Persdruk’:
event.source.data = event.source.parent.Persdruk
When I selected a different parameter the dataset of the box and whisker chart will not change. Can somebody see what I am doing wrong?
Thanks,
Mitchel
