I am trying to use Symbol Factory Version 3. Trying to copy and paste as .svg, I get this error:
com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Unexpected parsing error during XML deserialization.
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserializeXML(XMLDeserializer.java:398)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.readRootAttributes(XMLDeserializer.java:286)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.readRootAttributes(XMLDeserializer.java:282)
at com.inductiveautomation.factorypmi.designer.workspace.CopyPasteHandler.startPaste(CopyPasteHandler.java:168)
at com.inductiveautomation.factorypmi.designer.workspace.CopyPasteHandler.doPasteImpl(CopyPasteHandler.java:932)
at com.inductiveautomation.factorypmi.designer.workspace.CopyPasteHandler.doPaste(CopyPasteHandler.java:923)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$Handler.handlePaste(IgnitionDesigner.java:2779)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$Handler$15.actionPerformed(IgnitionDesigner.java:2337)
at java.desktop/javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at java.desktop/javax.swing.AbstractButton.doClick(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown Source)
at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
Caused by: org.xml.sax.SAXParseException; lineNumber: 1; columnNumber: 10; DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true.
at java.xml/com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserializeXML(XMLDeserializer.java:384)
... 44 more
Ignition v8.0.12 (b2020042115)
Java: Azul Systems, Inc. 11.0.6
Fixable, or no? FWIW, this latest revision has some nice advantages over the older version that a lot of graphics packages have been using.
