I was working on creating components for my project when Perspective started showing errors for the symbol I was working on. I thought I messed something up so I deleted the symbol and created another instance from the Symbol Factory, but that also had the same errors. I closed and reopened my project, but every symbol I place in a container has errors that seem to be incorrect.
The error says there is a problem with the stroke property, but the property appears to be configured correctly. I saw a post from May of 2020 with a similar issue, but there was no solution offered. I have tried multiple symbols on new views, but now they are all showing as least one and in one case 40 errors.
What is causing this behavior and how can I fix it?
Thank you,
Ali
