Symbol Factory resize in Perspective
Hello,
I’m trying to represent the architecture of the installation I’m working on by using Symbol Factory elements but as I don’t know how to resize the pipes, I have to connect several pipes together in order to have the desired length. Then, my View have a lot of components, and depending on the size of the screen, pipes don’t always connect well. Which parameter can we modify to adjust the width or the height of the elements of the Symbol Factory ?
Thanks,
Carla
I finally found a simple solution. By default, when we drag the element from the Symbol Factory to our view, the “preserveAspectRatio” property is set to “xMidYMid”, which prevents the image length from being changed independently. When setting this property to “none”, it is possible to resize the image as we want.
SVG size property
