Sync two ignition sever with an ignition Edge
Hi everyone. We have setup at site 1 Edge device installed version 8.3.3 which connected with two other standard ignition systems (version 8.3.3) through gateway network. Is it possible to sync historian data from Edge device to two other standard gateways at the same time?
Not directly from Edge to both gateways, at least not that I know of, anyway.
You can set up a Historian splitter on one of your standard gateways, and point Edge to sync to that splitter. From the splitter, you can target the other standard gateway historian, along with a local historian.
Thank you for your detailed response, I appreciate it.
