v8.0.15
Perhaps I assumed wrongly, but with resources now being simply files in v8, I thought that I would be able to copy the files for new or updated resources created on one gateway onto another gateway and that they would show up for use / update in the other gateway (after saving/updating), however this doesn’t quite appear to be the case…
I’m seeing the resource in the designer, but when I try to open it I get errors, as below.
What else do I need to do? Where is TemplateInfo stored?
Also, what’s stored in the .resources folder? it’s just a whole bunch of files with hex names
com.inductiveautomation.factorypmi.application.model.TemplateNotFoundException: TemplateInfo for template Receivals/Crushers/Dosing Status was null.
at com.inductiveautomation.factorypmi.application.model.TemplateManager.getTemplateInfo(TemplateManager.java:304)
at com.inductiveautomation.factorypmi.application.model.TemplateManager.getTemplateInstance(TemplateManager.java:153)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace.openTemplate(WindowWorkspace.java:1875)
at com.inductiveautomation.factorypmi.designer.model.navtree.TemplateNode.open(TemplateNode.java:125)
at com.inductiveautomation.ignition.designer.navtree.model.AbstractResourceNavTreeNode.onDoubleClick(AbstractResourceNavTreeNode.java:339)
at com.inductiveautomation.ignition.designer.navtree.NavTreePanel$MouseListener.lambda$mousePressed$0(NavTreePanel.java:676)
Ignition v8.0.15 (b2020072213)
Java: Azul Systems, Inc. 11.0.6
