Synchronize multiple tables scroll position
Need a little help. I have a table I'm trying to display in a Vision window. The data is coming from a named query, the table has more rows that would fit well on a screen, I would like to show all rows. I was going to break the query into two tables. I would like to synchronize the scrolling of both tables, is that possible? I asked ChatGPT and this is what it came up with:
An event script on one of the tables
if event.propertyName == 'verticalScrollPosition':
# Get the new scroll position of Table 1
newScrollPos = event.newValue
# Find Table 2
table2 = event.source.parent.getComponent('Table 2')
# Update Table 2's scroll position to match Table 1
table2.setVerticalScrollPosition(newScrollPos)
# Find Table 2
Look good to me however, it did not work. I did I print out the property event in the script (at the top of course), yet it never said the 'verticalScrollPosition' event when I scroll the scrollbar and of course, nothing happens. Needless to say, the synchronization of the scrolling bars did not work.
I look forward to your ideas and comments,
David
This will get you started. You should add a ChangeListener to sync the scrollbar positions.
In the initialize extension function on the first table add this script
	from javax.swing.event import ChangeListener
	tableMain = self.parent.getComponent('Power Table')
	table2 = self.parent.getComponent('Power Table 1')
	class myListener(ChangeListener):
		def stateChanged(self, e):
			scrollBarMain = tableMain.getVerticalScrollBar()
			scrollBar2 = table2.getVerticalScrollBar()
			scrollBar2.setValue(scrollBarMain.getValue())
	#to remove ChangeListener
	listeners = tableMain.viewport.getChangeListeners()
	for listener in listeners:
		tableMain.viewport.removeChangeListener(listener)
	#to add ChangeListener
	tableMain.viewport.addChangeListener(myListener())
You may want to consider this comment from a similar thread.
WOW, thank you so much for responding. You mentioned ' In the initialize extension function on the first table add this script', there is no initialize extension function from within the table's scripting.
The power table component has the initialize function, which I tend to use for its configuration flexibility over the regular table component. In a regular table you would move this script to the propertyChange event handler with a filter clause since you don't want to run the script on every property change.
if event.propertyName == 'componentRunning':
	# put your initialization code here
	tableMain = event.source.parent.getComponent('Table')
	table2 = event.source.parent.getComponent('Table 1')
This will only work in the designer if you enable preview mode before opening the window with the associated components.
