I use the AbstractVisionComponent
I’m looking for the synthax to add the Action/ActionPerformed capability on my component ?
All you have to do is override the initEventSets function on your component’s bean info class to include an actionPerformed event:@Override
protected void initEventSets() throws IntrospectionException {
super.initEventSets();
addEventSet(YourComponentClass.class, "action", ActionListener.class, "actionPerformed");
}Then make your component class either extends a swing component that has action listeners or make it yourself. It is easier if you extend a class that has them already.
If you make it yourself you have to add the following variable to your class:protected EventListenerList listenerList = new EventListenerList();Then you have to add three functions to your class:[code]public void addActionListener(ActionListener l) {
listenerList.add(ActionListener.class, l);
public void removeActionListener(ActionListener l) {
listenerList.remove(ActionListener.class, l);
public ActionListener[] getActionListeners() {
return (ActionListener[])(listenerList.getListeners(
ActionListener.class));
}[/code]Lastly, you will need to let the listeners know the event happened somewhere:protected void fireActionPerformed() {
Object[] listeners = listenerList.getListenerList();
ActionEvent e = null;
for (int i = listeners.length-2; i>=0; i-=2) {
if (listeners[i]==ActionListener.class) {
if (e == null) {
e = new ActionEvent(YourComponentClass.this,
ActionEvent.ACTION_PERFORMED,
"SomeAction");
((ActionListener)listeners[i+1]).actionPerformed(e);
}That is it!
just another question,
how to filter the event “SomeAction” in python script called on “actionPerformed”
I fire actionPerformed for 2 differents events : “action1”, “action2”
