I’m trying to combine two datasets and I want to use the addColumn method.
I create a tag history column with a dictionary and the append method then i convert to a dataset and then to a pyDataset, i pass it to the addColumn function but I get an error about the data ype of the column
Here’s the final part of the code with some prints that you can see in the console
print col_caravaggio
col_caravaggio = system.dataset.toDataSet(header_caravaggio, col_caravaggio)
#Dataset_finale
pydataset_caravaggio=system.dataset.toPyDataSet(col_caravaggio)
for row in pydataset_caravaggio:
for value in row:
print value
dataset_finale=system.dataset.addColumn(dataset_titec, pydataset_caravaggio,"CARAVAGGIO",float)
print dataset_finale
Your are using addColumn wrong, it expects a list of values for the column variable. You are passing in an entire dataset.
system.dataset.addColumn - Ignition User Manual 8.1 - Ignition Documentation (inductiveautomation.com)
Try
dataset_finale=system.dataset.addColumn(dataset_titec, col_caravaggio,"CARAVAGGIO",float)
That seems overly complicated to merge two datasets.
How do you want them joined ?
Let's say you have
[a1, a2, a3],
[b1, b2, b3]
[c1, c2, c3],
[d1, d2, d3]
do you want this:
[a1, a2, a3],
[b1, b2, b3],
[c1, c2, c3],
[d1, d2, d3]
or this:
[a1, a2, a3, c1, c2, c3],
[b1, b2, b3, d1, d2, d3]
the second case, i have two datasaet with the same numbers of rows
a = [
['a1', 'a2', 'a3'],
['b1', 'b2', 'b3']
b = [
['a4', 'a5', 'a6'],
['b4', 'b5', 'b6']
[x + y for x, y in zip(a, b)]
[['a1', 'a2', 'a3', 'a4', 'a5', 'a6'], ['b1', 'b2', 'b3', 'b4', 'b5', 'b6']]
replace a and b by your pyDataSets.
Alternatively, you could do it with basic datasets and addColumn, but frankly I tend to avoid those as I think they don't integrate well with python.
Thank you,
i ended up using the addColumn function at the end because is a bit more readeable and probably better for future maintenance.
For some reason i miread the doc and thought that the function required a pydataset instead of a python list.
Now it merges two tabels like I want to but the values all comes out with a lot of decimals ( i round them up with 2 decimals before addinf them to the list so it’s a function problems).
This is the output excel, the last column is the one I added
Any way to fix this?
more readable than [x + y for x, y in zip(a, b)] ?
I'd be curious to see the code that's more readable than a single list comprehension :X
Sometimes its not about being terse, but about being able to understand the script especially when you come back to it 6 months down the road.
Granted that is a fairly simple list comprehension, but if one is not use to it, it can look intimidating. A great time to learn it though!
