system.dataset.exportExcel?
Using system.dataset.exportExcel generates this error:
AttributeError: ‘com.inductiveautomation.ignition.common.script.Imm’ object has no attribute 'exportExcel’
The function is in the manual but does not appear when pressing Ctrl-Space.
Did I miss the memo that exportExcel no longer exists? I am using 8.1.5.
Where are you using the function?
In an action script on a button.
Vision or Perspective?
Sorry, in Perspective. Don’t tell me you can’t use it in Perspective… But I guess that makes sense.
you cant :frowning:
What is the best way to export in Perspective?
Can’t use it in perspective.
It’s a vision only scope.
Use system.dataset.toExcel and system.perspective.download.
Thanks. I sometimes forget how different the two really are.
Example:
