system.db.execSProcCall issue with SP call with out parameter
I am having an issue with the Stored Procedure call with output parameter.
Here is how I execute the SP in ignition script:
call = system.db.createSProcCall("VesselData_CreateVessel", "mydatabasename")
call.registerInParam("@vessel_name",system.db.VARCHAR,"IBC005")
call.registerOutParam("@return_value", system.db.VARCHAR)
system.db.execSProcCall(call)
I get this error code when executing. Please can anyone help?
com.inductiveautomation.ignition.common.script.JythonExecException: Traceback (most recent call last): File "", line 13, in onMessageReceived at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.error(AbstractDBUtilities.java:392) at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.execSProcCall(AbstractDBUtilities.java:530) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.base/java.lang.reflect.Method.invoke(Unknown Source) java.lang.Exception: java.lang.Exception: Error executing system.db.execSProcCall()
at org.python.core.Py.JavaError(Py.java:545)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:553)
at org.python.core.PyObject.__call__(PyObject.java:461)
at org.python.core.PyObject.__call__(PyObject.java:465)
at org.python.pycode._pyx1515.onMessageReceived$1(:15)
at org.python.pycode._pyx1515.call_function()
at org.python.core.PyTableCode.call(PyTableCode.java:173)
at org.python.core.PyBaseCode.call(PyBaseCode.java:306)
at org.python.core.PyFunction.function___call__(PyFunction.java:474)
at org.python.core.PyFunction.__call__(PyFunction.java:469)
at org.python.core.PyFunction.__call__(PyFunction.java:464)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:847)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:829)
at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$TrackingProjectScriptManager.runFunction(ProjectScriptLifecycle.java:868)
at com.inductiveautomation.ignition.common.script.ScriptManager$ScriptFunctionImpl.invoke(ScriptManager.java:1010)
at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$AutoRecompilingScriptFunction.invoke(ProjectScriptLifecycle.java:950)
at com.inductiveautomation.perspective.gateway.script.ScriptFunctionHelper.invoke(ScriptFunctionHelper.java:161)
at com.inductiveautomation.perspective.gateway.script.ScriptFunctionHelper.invoke(ScriptFunctionHelper.java:98)
at com.inductiveautomation.perspective.gateway.model.MessageHandlerCollection$MessageHandlerImpl$1.lambda$invoke$0(MessageHandlerCollection.java:86)
at com.inductiveautomation.perspective.gateway.threading.BlockingWork$BlockingWorkRunnable.run(BlockingWork.java:58)
Caused by: org.python.core.PyException: java.lang.Exception: java.lang.Exception: Error executing system.db.execSProcCall()
... 31 common frames omitted
Caused by: java.lang.Exception: Error executing system.db.execSProcCall()
... 30 common frames omitted
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: The index 0 is out of range.
at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDriverError(SQLServerException.java:237)
at com.microsoft.sqlserver.jdbc.SQLServerCallableStatement.registerOutParameter(SQLServerCallableStatement.java:112)
at com.microsoft.sqlserver.jdbc.SQLServerCallableStatement.registerOutParameter(SQLServerCallableStatement.java:2296)
at org.apache.commons.dbcp2.DelegatingCallableStatement.registerOutParameter(DelegatingCallableStatement.java:821)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper$SRCallableStatement.registerOutParameter(SRConnectionWrapper.java:1522)
at com.inductiveautomation.ignition.gateway.script.GatewayDBUtilities._callSProc(GatewayDBUtilities.java:320)
at com.inductiveautomation.ignition.gateway.script.GatewayDBUtilities._call(GatewayDBUtilities.java:383)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.execSProcCall(AbstractDBUtilities.java:528)
I've never had much luck with named parameters for this case. Try using parameter index numbers.
Thank you for the advice. I revised the script as follows and it works now:
			call = system.db.createSProcCall("VesselData_CreateVessel","MyDBName")
			call.registerReturnParam(system.db.INTEGER)
			call.registerInParam(1,system.db.VARCHAR,"IBC005")
However, it would be nice to get to the bottom of using the named parameters.
I used my parameters with the @ sign at the beginning as I do in the MSSQL server, but I've seen that the Ignition Manual uses the parameters without the @ sign in front. I tried using without @ sign to but still didn't work.
The SQL server JDBC driver is what's failing to find the parameter by name. In the version I skimmed, it has handling to automatically handle the presence or absence of a leading @. We're just handing the values you send over to the JDBC driver directly.
