'system.db.execUpdate()' with 'getKey = True' raise an exception
Hello,
I’m trying to run two named queries inside a form submission script.
The second one need the primary key of the first. So I enabled getKey, but now I get an exception inside the the function system.db.execUpdate().
A bug ?
Thank you :slight_smile:
My script :
def handleSubmission(session, name, data, formContext, sessionContext, retry):
    recipeParameters = {k: v for k, v in data.items() if k != 'categories'}
    recipe_id = system.db.execUpdate(path = 'Recipes/AddRecipe', parameters = recipeParameters, getKey = True) # <------- error here
    for category in data['categories']:
	    categoryParameters = {'recipe_id': recipe_id, 'category_id': category}
	    system.db.execUpdate(path = 'Recipes/AddCategoryToRecipe', parameters = categoryParameters)
    result = {'success': True}
    result
And the exception raised on the first query
com.inductiveautomation.ignition.common.script.JythonExecException: Traceback (most recent call last): File "<function:handleSubmission>", line 3, in handleSubmission at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.execUpdate(AbstractDBUtilities.java:718) at jdk.internal.reflect.GeneratedMethodAccessor137.invoke(Unknown Source) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.base/java.lang.reflect.Method.invoke(Unknown Source) java.lang.ClassCastException: java.lang.ClassCastException: class java.lang.Long cannot be cast to class java.lang.Integer (java.lang.Long and java.lang.Integer are in module java.base of loader 'bootstrap')
at org.python.core.Py.JavaError(Py.java:545)
at org.python.core.Py.JavaError(Py.java:536)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:192)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:563)
at org.python.core.PyObject.__call__(PyObject.java:400)
at org.python.pycode._pyx226.handleSubmission$1(<function:handleSubmission>:14)
at org.python.pycode._pyx226.call_function(<function:handleSubmission>)
at org.python.core.PyTableCode.call(PyTableCode.java:173)
at org.python.core.PyBaseCode.call(PyBaseCode.java:306)
at org.python.core.PyFunction.function___call__(PyFunction.java:474)
at org.python.core.PyFunction.__call__(PyFunction.java:469)
at org.python.core.PyFunction.__call__(PyFunction.java:464)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:851)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:833)
at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$TrackingProjectScriptManager.runFunction(ProjectScriptLifecycle.java:1167)
at com.inductiveautomation.ignition.common.script.ScriptManager$ScriptFunctionImpl.invoke(ScriptManager.java:1003)
at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$AutoRecompilingScriptFunction.invoke(ProjectScriptLifecycle.java:1249)
at com.inductiveautomation.perspective.gateway.script.SessionScriptFunctionHelper.execute(SessionScriptFunctionHelper.java:98)
at com.inductiveautomation.perspective.gateway.script.ScriptFunctionHelper.invoke(ScriptFunctionHelper.java:103)
at com.inductiveautomation.perspective.gateway.script.ScriptFunctionHelper.invoke(ScriptFunctionHelper.java:70)
at com.inductiveautomation.perspective.gateway.form.FormSubmissionManagerImpl$FormSubmissionTask.run(FormSubmissionManagerImpl.java:218)
at com.inductiveautomation.perspective.gateway.threading.BlockingWork$BlockingWorkRunnable.run(BlockingWork.java:58)
Caused by: org.python.core.PyException: java.lang.ClassCastException: java.lang.ClassCastException: class java.lang.Long cannot be cast to class java.lang.Integer (java.lang.Long and java.lang.Integer are in module java.base of loader 'bootstrap')
... 27 common frames omitted
Caused by: java.lang.ClassCastException: class java.lang.Long cannot be cast to class java.lang.Integer (java.lang.Long and java.lang.Integer are in module java.base of loader 'bootstrap')
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
... 24 common frames omitted
Can you share the queries and the entire script? It's hard to troubleshoot line numbers when you don't have the rest of the script. Also there is a cast Long to Int error there and we would need to see the query setup for params.
The query (I’m using PostgreSQL)
INSERT INTO recipes (title, description, servings, prep_time, cook_time)
VALUES
	(:title, :description, :servings, :prep_time, :cook_time)
And this is the entire script. It’s coming from a form from. I just added the ‘def handleSubmission()’ line at the top in my initial post.
This looks like it's just a bug in the implementation of system.db.execUpdate. It's assuming the result will be java.lang.Integer and, in this case, it's java.lang.Long.
I made a ticket (IGN-14299).
Thank you, I found a workaround
With PostgreSQL you can add at the end of the query.
RETURNING id
And then instead of ­­execUpdate(), just use execQuery()
