system.db.runUpdateQuery Error
Am trying to update a table using
system.db.runUpdateQuery(""“UPDATE public.“limits” SET “LSL”=‘10’ WHERE “ID”=‘2’;”"", “postgres”)
But I get this error:
File “”, line 1, in
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.error(AbstractDBUtilities.java:362)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runUpdateQuery(AbstractDBUtilities.java:183)
java.lang.Exception: java.lang.Exception: Error executing system.db.runUpdateQuery(UPDATE public.“limits” SET “LSL”=‘10’ WHERE “ID”=‘2’;, postgres, , false)
at org.python.core.Py.JavaError(Py.java:552)
at org.python.core.PyReflectedFunction.call(PyReflectedFunction.java:188)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.call(ScriptManager.java:514)
at org.python.core.PyObject.call(PyObject.java:497)
at org.python.core.PyObject.call(PyObject.java:501)
at org.python.pycode._pyx13.f$0(:1)
at org.python.pycode._pyx13.call_function()
at org.python.core.PyTableCode.call(PyTableCode.java:171)
at org.python.core.Py.runCode(Py.java:1614)
at org.python.core.Py.exec(Py.java:1658)
at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:276)
at org.python.util.InteractiveInterpreter.runcode(InteractiveInterpreter.java:131)
at org.python.util.InteractiveInterpreter.runsource(InteractiveInterpreter.java:116)
at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$InterpreterWorker.doInBackground(JythonConsole.java:506)
at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$InterpreterWorker.doInBackground(JythonConsole.java:494)
at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
Caused by: java.lang.Exception: Error executing system.db.runUpdateQuery(UPDATE public.“limits” SET “LSL”=‘10’ WHERE “ID”=‘2’;, postgres, , false)
… 27 more
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Cannot run this function when in read-only mode.
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:374)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:273)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:268)
at com.inductiveautomation.ignition.client.script.ClientDBUtilities._runUpdateQuery(ClientDBUtilities.java:189)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runUpdateQuery(AbstractDBUtilities.java:181)
… 25 more
File “”, line 1, in
Got it fixed. It was the damn client security.
Thanks.
