System db update the data into the latest record
Hi guys,
I’m trying to implement a value changed script to update the end_time to the row that already had start_time logged. At the moment, I’m able to insert them into 2 separate rows. Please see attached pics and code!
start_time= system.date.format(system.date.now(), "yyyy-MM-dd HH:mm:ss")
end_time= system.date.format(system.date.now(), "yyyy-MM-dd HH:mm:ss")
if previousValue.value == False and initialChange == False :
 	system.db.runPrepUpdate("INSERT INTO downtime_data.downtime_debarker (start_time) VALUES (?)",[start_time],"downtime_data")
if currentValue.value == False and initialChange == False :
 	system.db.runPrepUpdate("INSERT INTO downtime_data.downtime_debarker (end_time) VALUES (?)",[end_time],"downtime_data",)
I’m not sure I understand the problem but I think there are two issues:
  1. You might be looking for a Python None rather than False. (They’re not the same.) Try
    if previousValue.value is None and initialChange is None:
  2. If you’re trying to update end_time then use the SQL UPDATE command rather than insert. The raw SQL syntax is,
UPDATE table_name
SET column1 = value1, column2 = value2, ...
WHERE condition;
The Ignition script syntax would be like,
query = ('UPDATE downtime_data.downtime_debarker '
		+ 'SET end_time= ? '
		+ 'WHERE start_time = ? ')
args = [end_time, start_time]
system.db.runPrepUpdate(query, args)
What is `“downtime_data”? You have it quoted so that’s just going to be a string “downtime_data” rather than the contents of the down_time variable.
  1. It is a boolean tag. So, I’m just trying to make valued change script from this boolean tag, and skip the quality of the tag which is initialChange.
  2. With a bit changes, I’ve made it successfully based on Transistor’s help:
			+ 'ORDER BY start_time DESC ' +'LIMIT 1' )
	args = [end_time]
			system.db.runPrepUpdate(query, args,"downtime_data")
Basically, it will update the end_time to the latest record of start_time whenever the boolean tags changes its value.
Thanks for your help Transistor!!!
“downtime_data” is my SQL database name. IDK why it only works with this syntax inside. Maybe I have various databases.
Tip: use the </> code formatting button to preserve indentation and avail of syntax highlighting. It’s especially important for Python code. Can you fix your answer (pencil icon) to make it readable? Thanks!
Oops! Learn new things every day. Cheers Transistor!
