system.device.addDevice specifying deployment mode
I am using 8.3.9 and am trying to use the function system.device.addDevice to add Modbus device connections from a CSV. All the devices have a Simulator connection inside connected to my dev Deployment Mode. Is there a way to specify which deployment mode I will be adding the device to instead of it defaulting to core? This way it won't fail because a device will already exist under that name.
If you need to target a specific deployment mode, you need to go to the system.config scripting functions:
It is, unfortunately, pretty verbose because we don't currently have a mechanism to "fold in" defaults provided by the underlying driver/configuration type.
Or another draft with the same base functionality as provided by Claude:
DEVICE_MODULE_ID = "com.inductiveautomation.opcua"
DEVICE_TYPE_ID = "device"
# The driver reads its address map from this resource data file. The format is the same as the CSV
# the Gateway's "Export CSV" button produces, but with the lines joined by '|' instead of newlines.
ADDRESS_MAP_KEY = "address-map.txt"
def csvToAddressMap(csvText):
	Converts the Gateway's address-map CSV export format to the stored address-map.txt format.
	CSV layout (no header row):
		line 1:   designator radix, e.g. 10
		line 2..: prefix,start,end,step,unitId,addressType,modbusStart
		          e.g. HR,1,100,false,1,HoldingRegister,1
	addressType is the AddressType enum name (HoldingRegister, HoldingRegisterFloat, Coil,
	DiscreteInput, InputRegisterUInt16, ...). Malformed rows are silently dropped by the driver.
	lines = [line.strip() for line in csvText.splitlines() if line.strip()]
	return "|".join(lines)
def createModbusTcpDevice(
		name,
		hostname,
		addressMapCsv=None,
		collection=None,
		port=502,
		enabled=True,
		description=None):
	settings = {
		"connectivity": {
			"hostname": hostname,
			"port": port,
			"localAddress": "",
			"communicationTimeout": 2000,
		"requestOptimization": {
			"maxHoldingRegistersPerRequest": 125,
			"maxHoldingRegistersPerWriteRequest": 123,
			"maxInputRegistersPerRequest": 125,
			"maxCoilsPerRequest": 2000,
			"maxDiscreteInputsPerRequest": 2000,
			"concurrentRequests": 1,
			"spanGaps": True,
		"writeRequests": {
			"writeMultipleRegistersRequestAllowed": True,
			"forceMultipleRegisterWritesEnabled": False,
			"writeMultipleCoilsRequestAllowed": True,
		"readRequests": {
			"readMultipleRegistersRequestAllowed": True,
			"readMultipleCoilsAllowed": True,
			"readMultipleDiscreteInputsAllowed": True,
		"advanced": {
			"reconnectAfterConsecutiveTimeouts": True,
			"reverseWordOrder": False,
			"zeroBasedAddressing": False,
			"maxRetryCount": 1,
		"stringHandling": {
			"reverseByteOrder": False,
			"rightJustifyStrings": False,
			"readRawStrings": False,
	config = {
		"profile": {
			"type": "ModbusTcp",
		"settings": settings,
	kwargs = {
		"moduleId": DEVICE_MODULE_ID,
		"typeId": DEVICE_TYPE_ID,
		"name": name,
		"config": config,
		"enabled": enabled,
	# Omit to use the resource type's preferred collection (normally "core").
	# Pass a deployment mode name (see system.config.getModes()) to scope the device to that mode.
	if collection is not None:
		kwargs["collection"] = collection
	if description is not None:
		kwargs["description"] = description
	if addressMapCsv is not None:
		kwargs["files"] = {ADDRESS_MAP_KEY: csvToAddressMap(addressMapCsv)}
	return system.config.create(**kwargs)
# --- Example usage ----------------------------------------------------------------------------
# Either read an exported CSV from disk on the gateway...
#   csv = system.file.readFileAsString("/path/to/modbus-config.csv")
# ...or build it inline:
csv = """10
HRF,1,20,false,1,HoldingRegisterFloat,101
C,1,32,false,1,Coil,1
DI,1,32,false,1,DiscreteInput,1
resource = createModbusTcpDevice(
	name="ModbusTcpScripted",
	hostname="10.0.0.50",
	addressMapCsv=csv,
	collection="dev",  # deployment mode; use None (or system.config.CORE) for the core collection
	description="Created via system.config.create",
print resource
